Discussion topic: I cannot access the recordings on my main sky box and my sky mini box says no satellite signal
This message was authored by: Clogs01
I can't access the recordings on my main sky box and it says no signal on my sky mini box
Re: I cannot access the recordings on my main sky box and my sky mini box says no satellite signal
@Clogs01
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Hi @Clogs01
Reboot the mini as above.
If you still cannot make or Access you recordings you possibly have a Hard drive issue and need to work through the following link
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
