This discussion topic has been answered Discussion topic: I can’t turn my sound up on my television
Message posted on 01 Dec 2023 09:09 AM
I can't turn up my sound on my television with Q box my television is a Samsung
Message posted on 03 Dec 2023 07:22 AM
Have you tried using the TV remote?
Message posted on 01 Dec 2023 09:14 AM
Re: I can’t turn my sound up on my television which is a Samsung
I can't turn up my sound on my Samsung Television i have sky Q box
Message posted on 01 Dec 2023 10:57 AM
did you find your specific Samsung model in the list when you set up the remote?
Message posted on 03 Dec 2023 07:19 AM
Re: I can’t turn my volume up on my television
I can't turn my sound up on my Samsung Television
Message posted on 03 Dec 2023 07:23 AM
I had a sky person arrive Called Craig he fixed my television but not I cannot hardly hear the sound I tried to turn it up as directed out new batteries in my remote there is sound but not loud enough to hear properly.
Message posted on 03 Dec 2023 07:32 AM
The remote is all I have to control my sound I had a sky man who got my television going but since he left I can't turn my volume up on my television.
Message posted on 03 Dec 2023 08:12 AM
Re: I am unable to turn up sound on my television
@Treek wrote:
I am unable to turn up my volume .
Hi @Treek Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
If you still cannot change your volume on the TV click on the link Here and follow "fixing a problem with my remote"
Message posted on 03 Dec 2023 08:28 AM
I've merged your posts from today into Fridays thread. You should have a TV remote as well from when you bought your TV but you also need to try the advice provided by @Quoman7
