8
This discussion topic has been answered Discussion topic: I can’t turn my sound up on my television
This message was authored by: Treek
I can't turn up my sound  on my television  with Q box  my television is a Samsung
Re: I can’t turn my volume up on my television
@Treek
Have you tried using the TV remote?
Avatar for Treek
Re: I can’t turn my sound up on my television which is a Samsung
I can't turn up my sound on my Samsung Television i have sky Q box
did you find your specific Samsung model in the list when you set up the remote?
Avatar for Treek
I can't turn my sound up on my Samsung Television
@Treek
Avatar for Treek
I had a sky person arrive Called Craig he fixed my television but not I cannot hardly hear the sound I tried to turn it up as directed out new batteries in my remote there is sound but not loud enough to hear properly.
Avatar for Treek
The remote is all I have to control my sound I had a sky man  who got my television going  but since he left I can't turn my volume up on my television.
Re: I am unable to turn up sound on my television
@Treek wrote:
I am unable to turn up my volume .
Hi @Treek Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
If you still cannot change your volume on the TV click on the link Here and follow "fixing a problem with my remote"
@Treek
I've merged your posts from today into Fridays thread. You should have a TV remote as well from when you bought your TV but you also need to try the advice provided by @Quoman7
Answered - Go to Answer
