3
This discussion topic has been answered Discussion topic: I can't pair my sky q remote.
This message was authored by: Oreilly465
I have tried pressing 7 and 9 then 1 and 3. But I do not get a message on the TV to pair the remote. Don't know what else to do.
This message was authored by: nigea99 Answer
Re: I can't pair my sky q remote.
hi @Oreilly465
after pressing & holding  7 & 9 together did the red led above the SKY logo button flash 4 times ?
If it did then you need to be aware that after it is reset it uses infrared until re-paired and needs direct line of sight of the box.
hi @Oreilly465
This message was authored by: bob1234
@Oreilly465 Try this link for help with your Q remotes
https://www.sky.com/help/diagnostics/sky-q-remotes/what-would-you-like-help-with.
If you get to the end and decide the remote is faulty click tried everything then need more help and or contact us and you get a form to order a replacement one free.
Avatar for Oreilly465
@nigea99 thank you so much. This has worked first time. Your a star. I have sat all night on the same channel
Answered - Go to Answer
