4
This discussion topic has been answered Discussion topic: I can’t get subtitles on itv x my tv is not a smart tv
This message was authored by: Debussy
I can't get subtitles on itvx.Do I need to buy a smart tv?
This message was authored by: MightyQuinn Answer
Re: I can’t get subtitles on itv x my tv is not a smart tv
Hi @Debussy   If subtitles are available for the particular programme you are watching:
On your Sky Q remote > Direction Up -> Direction Right-> Direction Right-> Subtitles On.
This message was authored by: bob1234
@DebussyYou should be able to use the box, from Sky's help files.
"Subtitles To turn subtitles on when watching a programme, press Select on your Sky Q remote, and select the S button. This won't work if you try it when the adverts are on."
Avatar for Debussy
Level 2 icon
Thank you very much. I have subtitles now.
Avatar for Debussy
Level 2 icon
Thank you I now have subtitles
