Discussion topic: I can’t get q box to switch on
This message was authored by: ColinSR
Box won't switch on
Re: I can’t get q box to switch on
@ColinSR wrote:
Box won't switch on
@ColinSR whats happening when you try to switch it off. Is the amder light going green
What happens if you press the amber light does that turn the box on ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
