Discussion topic: I can’t get on to my recorded programs
This message was authored by: Misso
I can't watch my recorded programs
Re: I can’t get on to my recorded programs
@Misso
What happens when you try? Any error messages on the screen?
Hi @Misso
If you also cannot make any new recordings then you may have a hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
