Discussion topic: I can’t get my tv or remote working
This message was authored by: Susieq2024
Message posted on 22 Jan 2024 07:16 PM
My tv and remote control not working-batteries have been replaced
Find out more
Message posted on 22 Jan 2024 07:21 PM
Re: I can’t get my tv or remote working
Hi @Susieq2024
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
