Discussion topic: I can’t get my mini box to work
This message was authored by: Martyn12
I can't get my sky mini box to work
This message was authored by: ThePope27
Re: I can’t get my mini box to work
Any error messages....
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Hi @Martyn12
Reboot the mini as above.
