Discussion topic: I can’t get my Sky remote to work
This message was authored by: Deborah77
I cannot get the Sky remote to operate the tv.  It was working before I reinstated the multi room package.
Re: I can’t get my Sky remote to work
@Deborah77 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
