Discussion topic: I can't connect to an 3rd party wifi with my sky q box
Message posted on 05 Sep 2024 04:28 PM
I have a sky q box and I have virgin media WiFi but on the sky box it won't let me select connect WiFi from a different company.
Message posted on 05 Sep 2024 05:17 PM
Re: I can't connect to an 3rd party wifi with my sky q box
Hi @Charlie103
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 05 Sep 2024 05:28 PM
I can't get that far the problem I have is that it won't let my select connect to Wi-Fi from another broadband provider.
Message posted on 05 Sep 2024 05:44 PM
@oldfella it just says connect to a Wi-Fi with different service provider but it won't let me click on it.
Message posted on 05 Sep 2024 05:59 PM
Hi @Charlie103
On your Q remote press and hold 7 & 9 on the remote until it's led flashes four times.
This will set the remote to infrared mode which will work all boxes in line of site.
Reboot the Q and try the Network reset again and then see if the remote will let you select the option,
Remember to point the remote at the Qbox
If you can get the Q box working then repair the remote by pressing 1 & 3 and following onscreen instructions.
Message posted on 05 Sep 2024 06:04 PM
@oldfella Do you just press 1 and 3 or press and hold then?
Message posted on 05 Sep 2024 06:08 PM
@oldfella this didn't work.
Message posted on 05 Sep 2024 06:16 PM
Hi @Charlie103
You only press 1 & 3 when you the get the main Q box connectected to your WiFi.
You leave the remote in infrared mode to allow you to make the selection in the Network reset.
Did you do just the 7 & 9 and then carry out the Network reset again?
Message posted on 05 Sep 2024 06:20 PM
Yes and then tried to connect and it still wouldn't let me select it.
Message posted on 05 Sep 2024 06:23 PM
Hi @Charlie103
Confirm exactly the steps you take when carrying out the Network reset.
Step by step
Message posted on 05 Sep 2024 06:29 PM
I unplugged the router for a couple of minutes and then went onto my sky q box.
Then I went and pressed the home button,
then press and held 7 and 9. The. Went to network and tried and it didn't work.
Message posted on 05 Sep 2024 06:40 PM
Hi @Charlie103
Did the led on the remote flash four times when you pressed 7 &
............ The. Went to network and tried and it didn't work.
To help I need to know exactly each step and what was selected and what was shown onscreen at each step
Message posted on 05 Sep 2024 07:11 PM
Yes it flashed 5 times on the remote.
