Discussion topic: I can’t connect my sky q mini box to a different tv
Message posted on 13 Nov 2023 06:09 PM
I have moved my sky a mini to an alternative tv in the house. I can't get it to connect. It's states press the . Button on the remote to connect it, however, this is not working and I can't progress
Message posted on 13 Nov 2023 07:30 PM
Re: I can’t connect my sky q mini box to a different tv
Hi @Deanlittle3
Reboot the mini as above.
