Discussion topic: I can not get the sky mini box to switch on as the light will not change from Brownlow to green
This message was authored by: Char222
Message posted on 09 Feb 2024 02:27 PM
The sky mini dish will not switch on. The light does not change from brown to green
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 09 Feb 2024 03:03 PM
Re: I can not get the sky mini box to switch on as the light will not change from Brownlow to green
@Char222 to make sure its not a fault with your remote try pressing the amber light as that is also the on button
