Discussion topic: I can not get my to in bedroom to work the box seems to be stuck and wasp is flashing
Message posted on 01 Jul 2025 10:47 PM
Help
Message posted on 01 Jul 2025 10:50 PM
Re: I can not get my to in bedroom to work the box seems to be stuck and wasp is flashing
I'd like to speak to someone regarding my sky q box
Message posted on 02 Jul 2025 05:31 AM
@Wrt007
You aren’t contacting Sky Customer Services here. This is predominantly a customer led discussion forum where Sky customers are available to help other customers.
Whats a flashing wasp on a Sky box? Please explain what is happening to presumably a mini box.
The Customer Service lines are not 24/7 so if it's not something we can help with you'll need to call Sky when the lines reopen.
Message posted on 02 Jul 2025 10:02 AM
Assume you are referring to the WPS leds @Wrt007
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
