Discussion topic: I am unable to pause / rewind live tv.
This message was authored by: GGDE
Re: I am unable to pause / rewind live tv.
Hi @GGDE
Have you tried rebooting your Q box?
Avatar for GGDE
Tried that. Unfortunately still doesn't work
Are you seeing any onscreen message @GGDE??
If you also cannot make new recordings you may have a hard drive issue.
If so see following link.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
This message was authored by: Bluejp
Is the box full with recordings? That can impact the pausing etc
This message was authored by: Southpole
Have had exactly the same issue for weeks now. If I unplug the SkyQ box to reset, it works once, then immediately starts doing the same thing again. Series link recordings also fail a few times a week due to a "Technical Fault". Box is likely 8+ years old. Need to get this sorted, please.
