Discussion topic: I am unable to get beyond stage 2 to reboot a q box. Internet ok and main TV functional
This message was authored by: PR8
Internet connected. Main box working.
Unable to get past stage 2 of reboot
Re: I am unable to get beyond stage 2 to reboot a q box. Internet ok and main TV functional
Hi @PR8
There are no stages to reboot.    There are stages to software updates.
Reboot is as follows.
If your box is stuck and you can't select options with the remote then
Reset your Q box remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the Q box.
Switch your Q box back on and you then you should be able to get past the setup issues.
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
