Discussion topic: I am having issues viewing certain channels after the heavy rain in North London
Message posted on 30 Nov 2024 11:40 AM
Most channels seem to work, but ITV1 HD gives this error:
This channel is currently affected by a problem with your satellite signal.
Please advise how I should proceed with this issue.
Message posted on 30 Nov 2024 11:42 AM
Re: I am having issues viewing certain channels after the heavy rain in North London
@Tenakha
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
