Discussion topic: I am fed up with the sky mini hub failing to maintain a constant picture. I pay a lot for Sky
This message was authored by: PROBLEM+WITH+SKY
I am fed up with my Sky mini constantly freezing the pictures. I pay a lot for Sky . I expect HD and a good picture. When I was with BT I had 3 booster. Sky simply can't provide the services I at for . Please sort it out.
Re: I am fed up with the sky mini hub failing to maintain a constant picture. I pay a lot for Sky
@PROBLEM+WITH+SKY  You're not talking to Sky via the forum, nothing will be sorted out on the back of a forum post.
Hi @PROBLEM+WITH+SKY
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
https://www.sky.com/help/home
Regarding your issue try the following
Reboot the mini as above.
Which would presumably suggest an extremely problematic wireless environment in which Q is very likely to struggle...
Having Sky Broadband as the ISP does nothing by itself to solve Q television issues.
