Discussion topic: I am connected but my remote can not shift up or down to select tv guide
This message was authored by: Colin107
I am connected to sky with intro page scrolling but remote not allowing to select tv guide
Re: I am connected but my remote can not shift up or down to select tv guide
@Colin107 try rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
