This discussion topic has been answered Discussion topic: How to switch off Audio description of speaker volume
Message posted on 22 Jul 2023 10:32 PM
Our Sky Q box suddenly decides now to tell us in a very loud voice, ignoring the actual volume set what our volume level is set at. Also with Unmutes. I have been through all the options and have switched on and off all the audio descriptions. No where does it give a specific option on the audio descrption on the speaker volume only.
Add to this that I am severely sight impaired and have great difficulty reading the instructions on the help. The feature of highlighting audio description available programs is useless as it makes the Guide selection all white - I cannot see what the program actually is.
Message posted on 23 Jul 2023 07:15 AM
hi @Bushalltop
This sounds like it is likely to be your TV itself rather than your SKY box - particularly as SKY itself does not control sound level - the remote is paired to your TV's IR setting
Try using your TV's own remote and searching settings in your TVs menus
hi @Bushalltop
Message posted on 03 Mar 2024 06:24 PM
Re: How to switch off Audio description of speaker volume
Hi, can I ask if you ever resolved this problem. I am experiencing the same thing at the moment
Message posted on 03 Mar 2024 10:19 PM
I find the problem was actually on the telly not the Sky Qbox. It was quite a long procedure to find it on the TV. I have a Sony TV bought about five years ago. I still find it strange that one accidental press on the remote control would have activated it. And there was no clear indication of what that button was on the remote control. In addition I only have 5% of my eyesight left so being Classified as being blind doesn't help.
Hope this helps
Message posted on 03 Mar 2024 11:07 PM
Thank you. It seems I have experienced the same problem-my dog lay on the remote control so I don't know how she selected the button that has caused the problem. I too have a Sony tv which I purchased about 6 years ago so its obviously something connected to their device. I will have to contact them for assistance but thanks for your response
Message posted on 04 Mar 2024 12:35 PM
You could use the microphone option on the remote which on ours is the middle button of the top row, To ask for audio description off Or something similar. Our button has fallen off and it wasn't from overuse. I hardly ever talk to the Telly or the sky box any more as I can't really see the screen. However I still have to fix these technological items as I am the man in the house.!
