Discussion topic: How to get sky q on toshiba fire tv
This message was authored by: lizzyj63
How to get sky q on toshiba fire tv.  Connected to hdmi3.
This message was authored by: Clare255
Re: How to get sky q on toshiba fire tv
Have you fixed your problem?I am also having the same issue I can't get sky q to work through any hdmi port
Hi @Clare255 Have you just changed TV ?
Even if not , with the SKY Q box on, try pressing the following keys in sequence
Home 1 0 8 0 Home
Yes it is a brand new TV and it doesn't seem to recognise that the sky box is connect through the hdmi, I have just tried what you suggested with no success but thankyou anyway
This message was authored by: KarenAnderson26
I am having the same issue trying to connect my sky to my new Toshiba fore TV can anyone help lol
We did manage to get ours working in the end. To get it to work we had to do a factory reset on the tv
This message was authored by: AndreaN74
I'm struggling to connect my Sky tv to the Toshiba Fire Tv too
@AndreaN74 are you seeing any messages on the screen have you changed the TV source to the correct HDMI input ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
