Discussion topic: How to contact a sky engineer regarding a satellite issue
This message was authored by: Corkuser
No satellite message due to the satellite moving.need a contact no to arrange a sky engineer visit
Re: How to contact a sky engineer regarding a satellite issue
@Corkuser
The satellite hasn't moved although the dish may have.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
_________
To call Sky dial 150 (free) from a Sky Talk landline or a Sky mobile or alternatively use the following link
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
@Daniel0210 wrote:
@Corkuser
Depends on your frame of reference 😉
This message was authored by: c.tasker
Need a sky engineer to come out to look at sky dish
Please see @Daniel0210 's reply above
