14
This discussion topic has been answered Discussion topic: How to book an Engineer to fix Sky Q box
This message was authored by: MB555
Does anyone know how I can book an Engineer to fix multiroom Sky q box? It's constantly on standby. I have tried all trouble shooting fixes, I have tried ringing Sky and it send you back to online account saying you can book an engineer online but I cant see anywhere I can do this. Just going round in circles at the moment, thanks
This message was authored by: Mark39 Answer
Re: How to book an Engineer to fix Sky Q box
You can order a replacement box here after completing the checks: https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
Hi @MB555
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this
You need to contact Sky Directly.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
Avatar for MB555
Hi @oldfella, I tried fix as per your advice but still no joy. I will ring Sky directly and stay on until I get to speak with someone. Thank you for your help
Avatar for MB555
Hi @Mark39
I ordered a new box through the link you posted, quick and easy and is to arrive tomorrow hopefully - thanks for the advice!
@MB555
Remember to remove the viewing card before handing the box over to a courier.
Edit: only for a main Q box, not a Q Mini.
This message was authored by: Pete1561
Can anyone help in letting me know how to book an engineer visit. Lots of info to track one thats been booked but not to actually book. Already got through and had delivered a replacement SkyQ box but this hasn't solved the problem.
@Pete1561 probably best to contact Sky
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
What is the problem?
This message was authored by: Louiseburke
Hi I can't book an engineer. Having so many problems with Sky. No TV over Christmas and now no Internet or TV. No satellite signal. So frustrating and no way of booking an engineer. Las time it took 7 days for someone to arrive, can anyone help me on how I get in touch with Sky, tried calling and no reply and can't find link online to book a visit?
@Louiseburke what's the problem with booking an engineer?
I can't find a link to do so
@Louiseburke
To call Sky dial 150 (free) from a Sky Talk landline or a Sky mobile or alternatively use the following link which will lead to contact details which will hopefully (but not always unfortunately) include a phone number
UK customers: Scroll down and click on ‘Need more help’ leading to a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number.
The posting of full phone numbers isn’t permitted on the forum.
Any calls to Sky will initially be automated which may try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Alternative means of contact are:
(a) through the Sky Virtual Assistant on the same page - depending on your query, which can connect you with a live agent virtually if necessary or provide you with the contact number or
(b) via Skys social media sites (the links are at the bottom of this page).
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia.
The posts above say it's better to call them
I think the troubleshooter on sky.com might end with that but there's no direct "oi, send an engineer" link because it would overload the resources.
I know this is an old post, but one can go to:
https://www.sky.com/help/book-tv-visit
to book a visit without all the faff.
