Discussion topic: How to book a Sky engineer to fix no satellite signal
This message was authored by: lindsayw
I have no satellite signal
Re: How to book a Sky engineer to fix no satellite signal
@lindsayw
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
