Discussion topic: How do i book an Sky engineer to re route the cable for my Sky Q box?
This message was authored by: TJ87
I am moving my TV in the lounge, and the current cable from the dish needs extending and re routing. How do i book a sky engineer either online or by phone to do this?
I have been looking for over an hour now and continuously loop around the same pages with threadbare information.
Re: How do i book an Sky engineer to re route the cable for my Sky Q box?
hi @TJ87
If you have the MY SKY app I think you may be able to find a number there - especially if you are a SKY VIP member
If not go this page & scroll to the bottom and expand the link need more help & scroll down
https://www.sky.com/help/home
If you have SKY Mobile or SKY Talk land line then I think you can also call 150
BTW You can buy Satellite extension leads from quite a few sources so this may be a suitable option for you
This message was authored by: twilight+princess
Hi @TJ87 I've escalated your query so lookout for a chat invite - bubble - & click on this to speak with support.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
This message was authored by: Addie15
Hi there!    This matter be best dealt with by calling in, as this process will require an upfront payment, which we cannot process here.
Thanks.
@TJ87
Please note  that  moving the Satellite cable is usually chargeable and, as such, the escalation support team may not be able to assist with this
Edit - I see @Addie15 posted confirming this as I was typing
@TJ87
Sky charge about £65 for such work.
This message was authored by: Greenfingers001
Thanks for escalating this. We’ve sent @TJ87  an invite to chat.
Avatar for TJ87
Thank You All,
I went through the complaints section & spoke to someone very helpful in the text bubble. We aranged a date and time for the visit. Cost is £60 which is very reasonable.
Still none the wiser as to the actual method one should follow to book an engineer call out online. Hopefully i will not require one for sometime.
