Discussion topic: How do I order another multi screen box? We already have 1, wanting another for kids room.
Message posted on 13 Nov 2023 04:46 PM
Hi, how do I order another multi screen box?
How much are they?
thanks
Message posted on 13 Nov 2023 05:08 PM
Re: How do I order another multi screen box? We already have 1, wanting another for kids room.
How much are they?
thanks
Hi @Papito
You are best contacting Sky directly.
Minis come with a one off upfront charge of £50 for Activation.
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
It should also be remembered that minis cannot view UHD recordings or content.
