Discussion topic: How do I get my sky remote to turn my tv up
This message was authored by: Pashapetra
How do I get my sky  remote control to turn my television volume up
Re: How do I get my sky remote to turn my tv up
Hi @Pashapetra
Try completly resetting your Bluetooth remote.
Once it is paired to your Television you can change the volume, mute the sound and also turn the TV on or with a long press ( 2-3 secs) on the remote standby button.
@Pashapetra
Use this link to check depending on which remote you have
https://www.sky.com/help/articles/q-buttons-explained
it'll be a speaker symbol
Avatar for Pashapetra
Thanks everyone got it working
This message was authored by: TrudyH
Just bought a Samsung tv and I don't want to use 2 remotes want to use sky remote for the volume
