This discussion topic has been answered Discussion topic: How do I get my sky Q remote to turn off and on my TV
Message posted on 09 Sep 2024 02:09 PM
Re: How do I get my sky Q remote to turn off and on my TV
Thanks, but as Ijust posted, I never get the option of choosing which TV I have - I'm only ever directed to the screen instructing me to press and hold buttons 1 and 3 together, which never has any effect 😒
Message posted on 09 Sep 2024 02:23 PM
Is your Sky box in line of sight? That step depends on infra-red not bluetooth
Message posted on 09 Sep 2024 02:26 PM
- Yes @Chodley, Sky box is in sight less than 2m from remote when trying all these steps.
Message posted on 09 Sep 2024 02:44 PM
Does the flashing light happen like it should on the remote?
Message posted on 09 Sep 2024 02:46 PM
Yes, that happens as expected.
Message posted on 09 Sep 2024 02:50 PM
Which steps are you doing? The ones in the linked website or those in the "answer post" which I've personally never done.
Message posted on 09 Sep 2024 03:13 PM
I followed steps 1 to 3 per the link provided by @gombean at 1.25pm today. One of the earlier answers gave several steps beyond 3 but I never get beyond 3 and no choices of TV are listed.
Message posted on 09 Sep 2024 04:40 PM
@LynnSutherland Have you tried rebooting your Q box first ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 09 Sep 2024 04:48 PM
Message posted on 09 Sep 2024 06:13 PM
Ah, right. The only thing less painful then trying to call Sky is to get onto the chat/messenger service. You will talk to the bot for a while then a real agent. In doing this you can clearly show you have gone through all steps and the problem was not solved. In doing this over messaging where it is documented in full approval for a replacement remote should be faster and if it still does not work you will have a history of the process. Get a case reference number and take it from there - good luck 🤞
Message posted on 12 Dec 2024 07:23 AM
You can look on the back of your TV remote control to get the model number to input manually and the list will reduce with each digit. Also, look on the back of your TV for a sticker with the model number.
Message posted on 10 Mar 2025 10:54 AM
Spot on! been stuck on that on. Can just use the one remote now...thanks
Message posted on 16 Apr 2025 10:29 AM
I get the TV working only for it to not work once I have synced with my speakers (Rotel). It doesn't seem to support turning off your TV if you program speakers. Have you tried this? I used to have Virgin and it was very easy to setup both and it had a separate TV off button. The Sky remote only has one button and it only works for Sky box once you have setup speakers.
I've tried the 3 seconds and 5 seconds to turn off and it doesn't work. I may have to change my PS5 to not use the ARC port ☹️
Message posted on 16 Apr 2025 08:48 PM
Why do you need to sync it with the speakers? The TV should control those via arc anyway.
Message posted on 31 Jan 2026 01:25 PM
Just had this issue. You need to hold down the off button for a couple of seconds then it works.
