Discussion topic: How do I get Sky Q remote to access Q menu automatically on Sky glass TV?
Message posted on 02 Jan 2024 10:13 AM
I just went back to SKY Q but have kept my Sky glass tv, however to access the sky q menu I now need to scroll down and select HDMI inputs using the Sky glass TV remote. I have gone through all the help on here and Sky and can't find a solution to this, any ideas? It is annoying having to use 2 separate remote controls
Message posted on 02 Jan 2024 10:16 AM
Re: How do I get Sky Q remote to access Q menu automatically on Sky glass TV?
Hi @Gazro
Have you followed the steps here: https://www.sky.com/help/articles/connect-q-to-glass
As per step 5: Turning on HDMI CEC control on your Q box should turn your TV on and set it to the correct input.
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
Message posted on 02 Jan 2024 10:59 AM
Hi MikeAlanR
Yes I tried this, although my Q box is not a new one I followed the steps and hdmi is switched on, it seems that the Sky glass to is not compatible which seems rather short sighted in the least
Message posted on 02 Jan 2024 11:23 AM
So... with both Sky Glass and Sky Q in standby... when you activate the Sky Q box the Sky Glass doesn't activate?
Message posted on 02 Jan 2024 11:36 AM
Hi
yes the sky q remote activates the skyglass to howver to get to the Q menu I need to scroll down and select hdmi thus requiring 2 remotes at all times
Message posted on 02 Jan 2024 11:47 AM
Is the Sky Q box activated?
To clarify... Are both the Sky Glass TV and Sky Q box in standby when you activate the Sky Q box with the Sky Q remote?
Does the Sky Q box activate first then the Sky Glass TV activates?
Message posted on 02 Jan 2024 12:00 PM
Yes to all of the above
Message posted on 02 Jan 2024 12:53 PM
If the power is switched off and the plug for the Sky Q box pulled out ... does the standby button the Sky Q box remote activate the Sky Glass TV?
Message posted on 02 Jan 2024 02:18 PM
Yes using a long 3 second hold
Message posted on 02 Jan 2024 02:51 PM - last edited: 02 Jan 2024 02:52 PM
Interesting so CEC from the the Sky Q box is turning on the Sky GlassTV... but the Sky Glass TV is switch off the HDMI connection🤔
Is wifi switched off on the Sky Glass TV and there is no Ethernet cable attached to the Sky Glass TV and no aerial cable attached to the Sky Glass TV?
Message posted on 02 Jan 2024 07:26 PM
Wi-Fi is on the Sky glass but no Ethernet or aerial
Message posted on 02 Jan 2024 07:58 PM
Turn the wifi off so the Sky Glass TV is just a monitor attached to the Sky Q box🤔
Message posted on 03 Jan 2024 03:19 PM
Tried that and now the TV starts with the message no Wi-Fi get me connected and no other options
Message posted on 03 Jan 2024 06:45 PM
Is that message coming from the TV or is it the Sky Q box.... you do have the Sky Q box connected to the internet?
Message posted on 03 Jan 2024 07:08 PM
Amazing I have managed to resolve the issue, I was using a non provided hdmi cable, I put in the original cable and the setup starts hdmi automatically!
Sorry to waste any of your time but appreciate your help
