3
This discussion topic has been answered Discussion topic: How can I tell if my sky q box is using the ethernet cable or WiFi
This message was authored by: HARLEYDAVE
I recently hard wired my sky q box to the sky q router. I thought it would connect automatically but I still get buffering problems when streaming hd movies. How can I tell if the ethernet cable is being used. If I go to internet settings it just says broadband is connected and there's no indication of which is being used. I can find no option to choose either ethernet or WiFi.
This message was authored by: Chodley Answer
Re: How can I tell if my sky q box is using the ethernet cable or WiFi
Disable the wifi in the installer menu
It won't switch to ethernet unless you do a network reset and set it up explicitly.
Avatar for HARLEYDAVE
Thanks, do you know how to get to the installer menu
To enter the engineers menu do the following
press the home button then scroll down to settings and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Answered - Go to Answer
