7
This discussion topic has been answered Discussion topic: How can I improve SKYQ boxes connecting to each other. I use ZZOOMM ISP.
This message was authored by: LuluGold14
I was having all sorts of issues with wi-if/internet on SKY broadband as they do not provide fibre in my area. I had to switch devices off to try and get some stability and performance. Connection between SKYQ box and mini boxes was also unstable. I had to move to a new ISP to get full fibre which is great, but I still have the internal issue where SKYQ boxe to mini box connections as unstable. Is there a way I can improve the SKYQ connections between boxes ?.
many thanks in advance
Re: How can I improve SKYQ boxes connecting to each other. I use ZZOOMM ISP.
Hi @LuluGold14
Reboot the minis as above.
. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
Hi @LuluGold14
Avatar for LuluGold14
Level 2 icon
Hi @oldfella
many thanks. Been there and done that so many times, but it's one box that's has the issue and I think it's due to the fact that the SKY router has gone which reduced the gap. I had thought of a SKYQ booster but it suggests they only work if SKY is the ISP. Happy to give a SKYQ booster a go if they will work with other ISPs. Also if that's the case which one should I look at ?.
Thanks in advance
@LuluGold14 wrote:
Hi @oldfella
Thanks in advance
Hi @LuluGold14
You need a Sky Q WiFi booster from Sky.  They supply these free of charge to aid Q connectivity.  Although they will not connect to the non Sky router you can use them midway between the main Q box and the minis.   They are then connected by WPS the main Q box and then the minis use these for connection by WPS.
Level 2 icon
Many thanks @oldfella I will give it a go
Level 2 icon
Hi @oldfella
Update - I went through the process with SKY and they no longer just send out the SKYQ WiFi boosters. They arrange for an engineer to come out and if they agree and it will work they will provide a SKYQ booster. Earliest date 21st June, but they may find me an earlier date. Thought it would have been cheaper just to send a booster. But we will see.
This message was authored by: ftballman
I had heard something that boosters weren't so easy to get but wow 6 week? wait seems excessive.
If it's something you are familiar with and anxious to try ahead of that maybe have a look into powerline adaptors. Just be aware reliability depends on factors like how the house is wired. ( So if purchasing use somewhere with a good return option)
Level 2 icon
Thanks. They came up with an earlier date. Booster in and then they switched the mesh network on. Tried to live with it for a day, but finally disabled the mesh network. Everything very slow regarding SKY, just seemed flakey. Used WPSconnection to booster for mini box with most issues. Not sure it's working all that well as last night 27th May we have all sorts of issues with recordings failing due to tech issues and another mini box which has been stable since day one now cannot connect. May end up becoming a Virgin.
Answered - Go to Answer
