This discussion topic has been answered Discussion topic: How can I improve SKYQ boxes connecting to each other. I use ZZOOMM ISP.
Message posted on 02 May 2024 06:38 PM
I was having all sorts of issues with wi-if/internet on SKY broadband as they do not provide fibre in my area. I had to switch devices off to try and get some stability and performance. Connection between SKYQ box and mini boxes was also unstable. I had to move to a new ISP to get full fibre which is great, but I still have the internal issue where SKYQ boxe to mini box connections as unstable. Is there a way I can improve the SKYQ connections between boxes ?.
many thanks in advance
Message posted on 02 May 2024 07:31 PM
Hi @LuluGold14
Reboot the minis as above.
. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
Hi @LuluGold14
Message posted on 09 May 2024 09:44 AM
Re: How can I improve SKYQ boxes connecting to each other. I use ZZOOMM ISP.
Hi @oldfella
many thanks. Been there and done that so many times, but it's one box that's has the issue and I think it's due to the fact that the SKY router has gone which reduced the gap. I had thought of a SKYQ booster but it suggests they only work if SKY is the ISP. Happy to give a SKYQ booster a go if they will work with other ISPs. Also if that's the case which one should I look at ?.
Thanks in advance
Message posted on 09 May 2024 10:21 AM
@LuluGold14 wrote:
Hi @oldfella
Thanks in advance
Hi @LuluGold14
You need a Sky Q WiFi booster from Sky. They supply these free of charge to aid Q connectivity. Although they will not connect to the non Sky router you can use them midway between the main Q box and the minis. They are then connected by WPS the main Q box and then the minis use these for connection by WPS.
Message posted on 09 May 2024 09:10 PM
Many thanks @oldfella I will give it a go
Message posted on 12 May 2024 01:13 PM
Hi @oldfella
Update - I went through the process with SKY and they no longer just send out the SKYQ WiFi boosters. They arrange for an engineer to come out and if they agree and it will work they will provide a SKYQ booster. Earliest date 21st June, but they may find me an earlier date. Thought it would have been cheaper just to send a booster. But we will see.
Message posted on 12 May 2024 01:51 PM - last edited: 12 May 2024 01:52 PM
I had heard something that boosters weren't so easy to get but wow 6 week? wait seems excessive.
If it's something you are familiar with and anxious to try ahead of that maybe have a look into powerline adaptors. Just be aware reliability depends on factors like how the house is wired. ( So if purchasing use somewhere with a good return option)
Message posted on 28 May 2024 08:34 AM
Thanks. They came up with an earlier date. Booster in and then they switched the mesh network on. Tried to live with it for a day, but finally disabled the mesh network. Everything very slow regarding SKY, just seemed flakey. Used WPSconnection to booster for mini box with most issues. Not sure it's working all that well as last night 27th May we have all sorts of issues with recordings failing due to tech issues and another mini box which has been stable since day one now cannot connect. May end up becoming a Virgin.
