Discussion topic: High pitch tone when pausing, ff or rw and changing apps
Message posted on 17 Mar 2023 02:58 PM
We get a high pitch tone when ever we change apps, ff, pause or rw saved programms. Our audio is set to 5.1 outpust to the TV via HDMI then from the TV via optical to our AV amp. We have the same set up on our Apple TV (HDMI 2 input to tv) and output from the TV to the AV amp via the same optical cable and this dosent have any issues. I set the Sky Q to sterio and this stops it happening, but on Dolby 5.1 or the other Dolby setting it occurs. I've done the reset via the hidden menuse several times but it still happens. As it stands our Sky Q box is the main suspect. Any thoughts.... or have we got a duff Sky Q box?
It i also noticable that the audio in Dolby 5.1 from the Sky Q box is poorer than the audio from the Sky App on the Apple TV box, so I don't think it's our TV or AV amp set up.
Message posted on 17 Mar 2023 03:20 PM
							Re: High pitch tone when pausing, ff or rw and changing apps
Hi @51monpb
This issue has occurred in the past with some Panasonic TV 's if I remember correctly.
Message posted on 17 Mar 2023 03:30 PM
Yes it is a Panasonic TV and a Sony AV Amp. So I take it that I can only really get streio sound from my Sky Q and not Dolby 5.1 if don't want it to happen? (scares the cat every time!)
I would have thought that if it was a Panasonic issue, it would have happened with other boxes.... I've been trying a Roku, Firestick etc... and not had this "feature'.... so I still think the ball is in Sky's court on this.
Message posted on 18 Mar 2023 06:52 AM - last edited: 18 Mar 2023 07:03 AM
It is mainly a Panasonic tv issue but has been noted on a few other tv sets using the same chips.
I can create the issue on Sky kit, VirginMedia kit and BT kit.
The tone appears when there is no audio being output by the connected device - so you get a short bleep when changing channels or audio formats - and a continuous bleep when on pause.
The issue only seems to occur on devices connect direct to the tv set - even if using ARC.
But devices connected direct to the amp - do not get the issue.
My feedback from Panasonic TV was that Sky, VirginMedia and BT - all have the same fault in their boxes.
It only seems to be with tv set-top-boxes and not streaming sticks with have different hardware.
I opened a case with Panasonic for this issue in 2018 - and it is still open.
@51monpb wrote:Yes it is a Panasonic TV and a Sony AV Amp. So I take it that I can only really get streio sound from my Sky Q and not Dolby 5.1 if don't want it to happen? (scares the cat every time!)
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Message posted on 18 Mar 2023 08:08 AM
@ozsat wrote:It is mainly a Panasonic tv issue but has been noted on a few other tv sets using the same chips.
@ozsat Many thanks for your informative reply. We reciently swoped over to a Panasonic after our Sony screen decided to fail due to age so don't have the option of swopping back. Due to this issue we have been using the Sky Q box less and less, so II guess we need to look at how to move forward knowing there isn;t going to be a fix for the problem anytime soon.
Message posted on 18 Mar 2023 08:50 AM
Can you not connect the SkyQ direct to the amp and watch that way? or is that what you do now?
Message posted on 18 Mar 2023 09:04 AM
@ozsat wrote:Can you not connect the SkyQ direct to the amp and watch that way? or is that what you do now
Unfortunatly the Sony Amp does not allow 4K pass through, so I'd have to drop the resolution, hence why we connect HDMI direct to the TV from both the SkyQ and Apple TV. But on the upside I would get Dolby 5.1 working without R2D2 chipping in.
So the choice is low resolution screen and perfect sound or 4K picture with tone bursts every time we do somthing on the Sky Q. Our cat is now on full alert everytime we reach for the remote.... just in case he has to do a vertical take off....
