Discussion topic: Hi there my sky constantly keeps disconnecting from the internet and my mini boxes don’t work either
This message was authored by: Jim551
Hi there
My sky q keeps constantly disconnecting from the WiFi and my mini boxes therefore don't work either
Re: Hi there my sky constantly keeps disconnecting from the internet and my mini boxes don’t work ei
@Jim551 wrote:
Hi there
Hi @Jim551
Try completely reconnecting your main Q box.
This message was authored by: Gamer01000
Hi I am having the EXACT same problem and i PROMISE you this does not work it's nothing to do with the Internet it's a problem with the sky boxes themselves iv tried what you said PLUS REMOVING as many devices from the Internet as possible and having a wired connection (this solves the sky q problem but the sky mini WILL still disconnect from the Internet (removed) sky do not know what is happening as all they have told me to do us "contact them" if it happens again fed up of paying for (removed) service. I'm sorry but apart from recalling ALL affected devices there is NO fiX.
Moderator note: Removed inappropriate language
This message was authored by: Dave+on+the+beach
Yrs its the new sky router. Wr had them out 9 times plus open reach 5 times. This over 9 months. -
I got so fed up i found someone who fixes computers etc. As i really thought it must be my new computers!
Anyway he arrives i explain the issues. He checks the network with some commands and then says 100% its not your computers! He then logs into the sky router. Goes thru the logs he says theres no dns servers. Means nothing to me. He explains their purpose.  So he resets the router dns server came back internet fine then goes away again. This chap then goes out to his van gets an older sky router out plugs it in sets it up. Bam internet after 5 minutes. Half an hour goes by no dropping. He sets up a wifi name and easy to remember password. Then says give it 10 days to settle and ill check back in a couple if weeks.
Well its been 100% fine with that old router. This chap true to his word calked upnin two weeks to check on us.! Sky you should train your your engineers like this person!
