Discussion topic: Hi problem finding my sky Q box on the network. I have multi rooms
Message posted on 13 Aug 2023 06:34 PM
I have tried everything I know switching off on mains. I have internet but none which to connect.
Message posted on 13 Aug 2023 06:42 PM
Re: Hi problem finding my sky Q box on the network. I have multi rooms
Assume you are trying to connect a mini and your main Q box is connected to your Network.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
