Discussion topic: Hi, power cut yesterday now sky q won’t connect to sky broadband
This message was authored by M3jack This message was authored by: M3jack
Hi, power cut yesterday now sky q won't connect to the broadband, I have tried resetting both router and sky, pressing wps but nothing happens, also tried manually entering password
Re: Hi, power cut yesterday now sky q won’t connect to sky broadband
Hi @M3jack
WPS can only be used with Sky Broadband.
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
M3jack
Thanks, Managed to reset, there was a software update and my recordings had taken up 96% of disc space, lowered it to 70%, did software update and connected afterwards
This message was authored by Invisiblename This message was authored by: Invisiblename
70%??!!  Blimey, you don't believe in deleting anything, do you!
I am just another Sky customer!
