Discussion topic: Hi, power cut yesterday now sky q won’t connect to sky broadband
Message posted on 21 Feb 2024 07:07 PM
Hi, power cut yesterday now sky q won't connect to the broadband, I have tried resetting both router and sky, pressing wps but nothing happens, also tried manually entering password
Message posted on 21 Feb 2024 07:30 PM
Re: Hi, power cut yesterday now sky q won’t connect to sky broadband
Hi @M3jack
WPS can only be used with Sky Broadband.
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Message posted on 21 Feb 2024 08:33 PM
Thanks, Managed to reset, there was a software update and my recordings had taken up 96% of disc space, lowered it to 70%, did software update and connected afterwards
Message posted on 21 Feb 2024 08:45 PM
@M3jack wrote:Thanks, Managed to reset, there was a software update and my recordings had taken up 96% of disc space, lowered it to 70%, did software update and connected afterwards
70%??!! Blimey, you don't believe in deleting anything, do you!
