Discussion topic: Hi, my skyq box keeps loosing sound
Message posted on 08 Sep 2024 02:28 PM
We have tested our TV and hdmi lead. We have to regularly turn.the box off at the switch wait over night and then it's fine. It's done this lots of times we are fed up with it. This happened with our last skyq box and the one we have now was it's replacement, but continues to happen
Message posted on 08 Sep 2024 02:38 PM
Re: Hi, my skyq box keeps loosing sound
Hi @TC661
Have you tried the various Audio options in your Q box?
ie
Home - Settings -Setup - Audio Visual
Try Normal - Dolby Digital etc.
See if they all give you the same issue
Message posted on 08 Sep 2024 02:46 PM - last edited: 08 Sep 2024 04:26 PM
This happening with two different boxes points at something else like the TV being the most likely culprit. How have you tested the TV? Have you tried a soundbar instead?
