Discussion topic: Hi my sky remote wont go to TV guide, so cant change channel or go to recordings either. Tried swit
This message was authored by: Scotland63
Done the same last night, and has been fine since TV went on this afternoon, but now same as last night, remote only letting me switch off, nothing else.
Re: Hi my sky remote wont go to TV guide, so cant change channel or go to recordings either. Tried
Tried batteries I assume?
Have you re-paired the remote to the box?
Avatar for Scotland63
@Chodley I have tried both but no luck
Rgds
When you say it's letting you switch off, is that by holding down the power button, i.e. it's turning the TV which now, on the latest sky firmware, also turns the Sky box off. Or does a quick press on the power button turn the sky box off?
