Discussion topic: Hi, my sky q box is showing is showing hard drive fault. I reset and it is still showing message.
This message was authored by: YvonneRoss
Message posted on 18 May 2024 09:33 AM
Hard disk fault, reset and message has returned.
Find out more
Message posted on 18 May 2024 09:38 AM
Re: Hi, my sky q box is showing is showing hard drive fault. I reset and it is still showing message
Then probably terminal and you'll need to call Sky for a replacement box.
Remember to remove your viewing card...
Find out more
Hi @YvonneRoss Try following the help pages which will lead you to requesting a replacement box if required.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
