Discussion topic: Hi my sky q box in my room is not working
This message was authored by: Leo2015
H my sky q mini box in my room is not working  it has a technical fault
Re: Hi my sky q box in my room is not working
@Leo2015
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Hi @Leo2015
Reboot the mini as above.
