5
This discussion topic has been answered Discussion topic: Hi my sky mini box keeps announcing the volume every time I change it
This message was authored by: Gs1234
This message was authored by: nigea99 Answer
Re: Hi my sky mini box keeps announcing the volume every time I change it
@Gs1234 wrote:
It's definitely not the tv as I do not use the tv remote its in a cupboard. My 1 year old had the the sky remote and has done this
@Gs1234
Personally, I really do think it is your TV  even if it seems unlikely - especially as you mention it referring to the HDMI also the SKY Q box doesn't know the actual volume level in use just that you press up /down.
Avatar for Gs1234
It also announces when screen is turned off and hdmi
hi @Gs1234
I think this may be a setting on your TV rather than the SKy Mini box
Try exploring the menus with your TV's own remote
Avatar for Gs1234
@Gs1234
The sky remote can control the TV volume. The sky box itself has no volume control.
