Discussion topic: Hi my mini of has no power light showing & the error message I’m gettibg is no input signal.
Message posted on 20 Jan 2024 05:27 PM
Hi my minibox has no green light showing a power supply even though it is plugged into my tv. The error message I'm getting is no input signal. Does this mean the minibox has failed? Please help.
Message posted on 20 Jan 2024 05:36 PM
Re: Hi my mini of has no power light showing & the error message I’m gettibg is no input signal.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
