This discussion topic has been answered Discussion topic: Hi my Sky Q box will not load recordings, also will not allow me to download anything j
Message posted on 15 Jul 2024 07:30 PM
When attempting to download a programme or movie just says there is a technical issue
Message posted on 15 Jul 2024 08:33 PM
@Ian171 wrote:
Hi @oldfella
Thabks for reply it won't load any recordings. When I also try to download on demand just says there is a technical issue try again later.
I can't access the reset menu either go to settings 0 0 1 but nothing happens. Powered on and off but no good.
Think I possibly may need a new box ?
Hi @Ian171
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 15 Jul 2024 07:54 PM
Re: Hi my Sky Q box will not load recordings, also will not allow me to download anything j
Message posted on 15 Jul 2024 08:31 PM
Hi @oldfella
@Ian171 wrote:
Hi @oldfella
Hi @Ian171
