Discussion topic: Hi, my Netflix and Disney apps are not visible to go on.
Message posted on 09 Mar 2023 11:57 AM
When I go to my apps,it is just showing the Peacock app, even though I have Netflix and Disney, they do not show. I have downloaded them and Activated them.
Message posted on 09 Mar 2023 12:04 PM
Re: Hi, my Netflix and Disney apps are not visible to go on.
Hi @St55
Have you tried refreshing the Apps in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
