1
This discussion topic has been answered Discussion topic: Hi, im having issues with my sky box staying connected
This message was authored by: pellens1j
Hiya, I'm having issues with my sky box staying connected to my WiFi. I have checked and deffo not an issue with my fibrenest router or connection. I habe reset in setting on my sky box but its still happening? I have checked all cables out the back and they are in and firmly in place.... any ideas? Had the box approx 2.5yrs now and never had an issue.
Re: Hi, im having issues with my sky box staying connected
Hi @pellens1j
Was it a Network reset that you did?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Hi @pellens1j
