Discussion topic: Hi im having connectivity issues with my mini box but now my remote won't work either.
This message was authored by: Deedee64
Had connectivity issues with mini box, then mini box sent it to the page with steps 1-4 to try and reconnect me but then remote stopped controlling the box
Re: Hi im having connectivity issues with my mini box but now my remote won't work either.
Hi @Deedee64
Set your mini remote to infrared mode by pressing and holding 7 & 9 together on the remote until it's led flashes 4 times.
Don't try to re pair it.
As the remote is in infrared you need to point it directly at the Mini and you should be able to get past step 1 of 4.
If you can get the Mini working then you can use 1 & 3 together on the remote to rebpair it.
