Discussion topic: Hi had a new media wall fitted now sky Q box is behind the false wall and I can’t get it to work
Message posted on 15 Apr 2024 12:41 PM
Hi had a new media wall fitted now sky Q box is behind the false wall and I can’t get it to work I thought the signal from the remote was Bluetooth and not infrared
Message posted on 15 Apr 2024 12:52 PM
Re: Hi had a new media wall fitted now sky Q box is behind the false wall and I can’t get it to work
Hi @Williecl
It is Bluetooth when correctly paired.
However to pair it does need line of sight.
Press and hold 7 & 9 together on the remote until it’s led flashes four times. (This sets the remote to infrared mode). Next step needs line of sight to Qbox.
Message posted on 15 Apr 2024 05:51 PM
Hi thanks for the reply I followed those steps still never worked I need to pull the tv out and go right close to the box
Message posted on 15 Apr 2024 06:06 PM - last edited: 15 Apr 2024 06:09 PM
Message posted on 15 Apr 2024 06:56 PM
I would get one of these to mitigate against issues like this again in the future.
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
