Discussion topic: Hi can't get the TVs connected to the Sky Box. Have tried repeatedly
This message was authored by: Steve2359
Re: Hi can't get the TVs connected to the Sky Box. Have tried repeatedly
hi @Steve2359
I think you may have to explain a little more - SKY Q boxes just connect to the  TVs via HDMI cables.
Are you having problems with a main box or a mini box or both & how are you trying to connect them & to what ?
What specific error messages are you getting ?
Avatar for Steve2359
Level 0 icon
It's the main box. It asked me to press the WPS button which I have done several times but still no connection. WiFi to other devices is working but not the the Q box it seems
Many thanks @Steve2359
Unfortunately not really my area of expertise but I am sure others may be able to advise.
Can I just check who is your home  wifi with  - is it SKY or a 3rd party and are you using their router or an independent router  ?
If SKy which router do you have ?
WPS doesn't connect a television to a main Q box: it links a main Q box to an internet router (or a television to a router).
