Discussion topic: Hi My skybox keeps restarting after shutting down and the Tv starts.
This message was authored by: rkuks
Since the last week after shutting the sky Q box, it restarts again and switches on the TV. This happens every time and only can be stopped by pulling the power cord from the Q box. Please help.
This message was authored by: bob1234
Re: Hi My skybox keeps restarting after shutting down and the Tv starts.
@rkuksThat should only happen if you hold the on/off button down for too long on the Q remote, check that it is not sticking.
Avatar for rkuks
I am afraid that is not the case.  I have checked and it's still happening. Last night it switched on the whole night. It even restarts even if the tv shuts automatically due to no activity.
Would suggest repairing your Sky q remote.
Pair the remote as in section 3 of this Sky q help article;
https://www.sky.com/help/articles/fix-remote
Avatar for rkuks
The remote is not the issue. I have removed the battery from both the sky and tv remote. It still switches on.  looks like there is a problem with the q box
This message was authored by: Doc5907
@rkukssounds like you need to call Sky and get an engineer out to have a look where, if they can't resolve the issue, it will be likely a box replacement.
Sky Q 1TB UHD
LG TV
Sky Mobile
We mention checking and repairing the remote, as we have seen others in this community with stuck/repairing remote glitches that have caused similar restarting problems in the past..
Avatar for rkuks
Just talked to a sky engineer. They asked me to change my settings in the preference to active. This seems to have worked. Will however wait to see.
Avatar for rkuks
The setting suggested by the sky advisor has not worked. Have had to remove the power cable as it keeps restarting.
